Problem with VPN connection with a PIX to a W2K server!!!
I have a cisco pix firewall and I'm trying to connect outside PC to my inside network..
I'm using a cisco VPN client 3.6.3...and IPsec
Right now the connection is made between the PIX via the VPN but I can't see or logon to the inside network...
Can you help me with that....
What are the access-list or port that I should allow to make the connection to the server possible???
Thanks in advance
Bronze
Re: Problem with VPN connection with a PIX to a W2K server!!!
when you connect via the vpn client(with normal config), you can acess anything on IP, so that should not be a problem, can you ping those servers by IP address and name both, if not by name, do you have WINS/DNS servers IPs pushed to the clients, please make sure that you do that.
Thx
Afaq
do I need to enter the DNS server addres in the VPN configuration in the PIX ????
Also, you mean that we don't need access-list when using VPN...right??
And the problem is I can't ping the server from the outside..but I don't see it to logon to it....
Here's my configuration to help you
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside 216.46.16.30 255.255.255.0
ip address inside 172.16.244.10 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool test 173.16.244.100-173.16.244.120
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 216.46.16.22 172.16.244.13 netmask 255.255.255.255 0 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn address-pool test
vpngroup vpn wins-server 173.16.244.13
vpngroup vpn default-domain biotest
vpngroup vpn split-tunnel dynacl8
vpngroup vpn idle-time 1800
vpngroup vpn password ********
telnet timeout 5
ssh timeout 5
96
