Problem with VPNClient 3.7 in Mac10.2
I've installed the Cisco VPNClient 3.7 in MacOS10.2. I've created a new connection profile with the necessary parameters mainly like VPN Server IP, Preshared Key. I've connected My Mac10.2 using Dialup and I tried to connect the VPN. It says "Remote Peer is no longer responding".
But When I tried using VPNClient 3.5 in another Mac10.1 machine the vpn connectivity is working without any problem with the same connection profile parameters (Checked my profile of sample.pcf files in both the machines).
Its produces the following log messages while I connecting the Client 3.7 in Mac10.2, Please suggest me what could be the cause of failure.
196 15:12:21.519 12/14/2002 Sev=Info/4 CM/0x43100002
Begin connection process
197 15:12:21.522 12/14/2002 Sev=Info/4 CM/0x43100004
Establish secure connection using Ethernet
198 15:12:21.522 12/14/2002 Sev=Info/4 CM/0x43100026
Attempt connection with server "x.x.x.x"
199 15:12:21.523 12/14/2002 Sev=Info/6 IKE/0x4300003B
Attempting to establish a connection with
x.x.x.x.
200 15:12:22.233 12/14/2002 Sev=Info/4 IKE/0x43000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID, VID,
VID) to x.x.x.x
201 15:12:22.235 12/14/2002 Sev=Info/4
IPSEC/0x43700009
IPSec driver already started
202 15:12:22.235 12/14/2002 Sev=Info/4
IPSEC/0x43700014
Deleted all keys
203 15:12:22.884 12/14/2002 Sev=Info/5 IKE/0x4300002F
Received ISAKMP packet: peer = x.x.x.x
204 15:12:22.885 12/14/2002 Sev=Info/4 IKE/0x43000014
RECEIVING <<< ISAKMP OAK INFO
(NOTIFY:NO_PROPOSAL_CHOSEN) from x.x.x.x
205 15:12:22.885 12/14/2002 Sev=Info/5 IKE/0x4300004A
Discarding IKE SA negotiation
206 15:12:27.239 12/14/2002 Sev=Info/4 CM/0x43100014
Unable to establish Phase 1 SA with server
"x.x.x.x" because of
"DEL_REASON_PEER_NOT_RESPONDING"
207 15:12:27.239 12/14/2002 Sev=Info/4 CM/0x43100011
Attempt connection with backup server
"x.x.x.x"
208 15:12:27.239 12/14/2002 Sev=Info/4 CM/0x43100026
209 15:12:27.240 12/14/2002 Sev=Info/6 IKE/0x4300003B
x.x.x.x.
210 15:12:27.454 12/14/2002 Sev=Info/4 IKE/0x43000013
VID) to x.x.x.x
211 15:12:27.833 12/14/2002 Sev=Info/4
IPSEC/0x43700009
212 15:12:27.833 12/14/2002 Sev=Info/4
IPSEC/0x43700014
Deleted all keys
213 15:12:28.118 12/14/2002 Sev=Info/5 IKE/0x4300002F
214 15:12:28.118 12/14/2002 Sev=Info/4 IKE/0x43000014
215 15:12:28.118 12/14/2002 Sev=Info/5 IKE/0x4300004A
216 15:12:32.696 12/14/2002 Sev=Info/4 CM/0x43100014
217 15:12:32.696 12/14/2002 Sev=Info/4 CM/0x43100011
"x.x.x.x"
218 15:12:32.696 12/14/2002 Sev=Info/4 CM/0x43100026
219 15:12:32.697 12/14/2002 Sev=Info/6 IKE/0x4300003B
x.x.x.x.
220 15:12:32.889 12/14/2002 Sev=Info/4 IKE/0x43000013
VID) to x.x.x.x
221 15:12:33.256 12/14/2002 Sev=Info/4
IPSEC/0x43700009
222 15:12:33.256 12/14/2002 Sev=Info/4
IPSEC/0x43700014
Deleted all keys
223 15:12:33.621 12/14/2002 Sev=Info/5 IKE/0x4300002F
224 15:12:33.621 12/14/2002 Sev=Info/4 IKE/0x43000014
225 15:12:33.621 12/14/2002 Sev=Info/5 IKE/0x4300004A
226 15:12:38.197 12/14/2002 Sev=Info/4 CM/0x43100014
227 15:12:38.197 12/14/2002 Sev=Info/4 CM/0x4310000C
All connection attempts with backup server failed
228 15:12:38.197 12/14/2002 Sev=Info/5 CM/0x43100027
Initializing CVPNDrv
229 15:12:38.749 12/14/2002 Sev=Info/4
IPSEC/0x43700009
230 15:12:38.749 12/14/2002 Sev=Info/4
IPSEC/0x43700014
Deleted all keys
Thanks and Regards,
Karthikeyan V
  • Other Security Subjects
Bronze
Re: Problem with VPNClient 3.7 in Mac10.2
Hi Karthikeyan
Seems like your concentrator is not accepting something in the proposal. Can you enable the following events in your concentrator and see what's happening:
Enable:
IKE 1-9
IKEDBG 1-9
IKEDECODE 1-13
Jazib
Unfortunately I'm using PIX515 Firewall as my VPN Gateway.
When I tried with VPNClient 3.5 in Mac10.1 with the same profile parameters, Its working fine. Will VPNClient 3.6 supports Mac10.2.
When I look into the log messages it says the following message,
In my Mac m/c its having one ethernet net and one dialup, Why It should say the "using Ethernet".
If there is a problem in PIX, it should have not worked with other version of Mac10.1 with VPNClient 3.5. Even If there is a problem in Cisco VPNClient 3.7 configuration, I don't know the configuration other than the profile parameters in that(I'm using the same profile parameters in the another working profile).
I can give you the log messages of PIX if you prefer.
Thanks, Karthikeyan V
Bronze
The following messge is just an informational message:
Even if you use a dialup, wireless connection, it will stil say "using ethernet"
Anyway, can you send me the logs from the pix side "debug cry isa, and debug cry ip"
Jazib
I can get you only by tomorrow evening. I've seen the following in cisco.com website,
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/3_6/36client.htm
Note The VPN Client still supports DES/MD5; however, support for DES/SHA is no longer available. Because of the latter, Release 3.6 VPN Clients cannot connect to any central-site device group that is configured for (or proposing) DES/SHA. The VPN Client must either connect to a different group or the administrator for the central-site device must change the configuration from DES/SHA to DES/MD5 or another supported configuration. The VPN Client Administrator Guide lists all the supported encryption configurations.
I've installed 3.6, 3.6.1 and 3.6.2 in Mac 10.2.
I've configured "sha" in my cisco pix 515 fw. Should I test by changing that into md5. Anyhow i'll post you the debug messages to you by tomorrow.
Thanks for your information, Karthikeyan V
Finally I finished the task and the problem with the modification of sha to md5 in my pix515 firewall and its realy only with the vpnclient 3.6.x and above(3.7).
Thanks for your guidance and help.
Karthikeyan V
karthik@unityindia.com
115
