03-29-2006 06:27 AM - edited 02-21-2020 12:48 AM
New user of Cisco gear and this is my first question submitted here so please bear with me ...
Have a new PIX 506E with 6.3(5)
Have a Solaris system for a tftp server
Have the tftp-server configured on PIX as:
tftp-server inside clmco2223 /tftpboot
I have a name statement in the PIX config:
name 192.168.222.3 clmco2223
Permissions for /tftpboot on Solaris system are 777
Permissions for cldbcogw1.cfg file on Solaris system are 777
netadmin@clmco2223-$ cd /tftpboot
netadmin@clmco2223-$ ls -la
total 6
drwxrwxrwx 3 nobody other 512 Mar 29 06:59 .
drwxr-xr-x 35 root root 1024 Mar 29 06:47 ..
-rwxrwxrwx 1 root other 0 Mar 29 06:59 cldbcogw1.cfg
When I attempt to execute the write net command, here's what I get ...
cldbclgw1(config)# write net :cldbcogw1.cfg
Building configuration...
TFTP write '/tftpboot/cldbcogw1.cfg' at clmco2223 on interface 1
Access violation
[FAILED]
If I manually tftp from another system to this one (clmco2223), the transfer works fine.
Does anybody have any insight?
Roy
03-29-2006 06:36 AM
Looks like the TFTP Server allows just to write in existing local files.
Create a file with the name < cldbcogw1.cfg > in the Solrais TFTP Server directory.
cd ../Folder of TFTP Server/
touch cldbcogw1.cfg
And then try again to write the file.
Hope that helps
Patrick
03-29-2006 07:59 AM
Appreciate the reply ...
I'd already done what you had suggested.
" Permissions for /tftpboot on Solaris system are 777
total 6
-rwxrwxrwx 1 root other 0 Mar 29 06:59 cldbcogw1.cfg "
Any other suggestions?
03-29-2006 12:48 PM
Hmm I allready had the same problem with a secure tftp server but I do not remember what exactly I had done. I think you need 777 on an allready created file. Use also the < /filename >.
Add this line into your PIX:
tftp-server interface-name TFTPServerIP /filename
Then execute:
wr net
sincerely
Patrick
