problems connecting outside
we recently got PIX i was setting up in a testing lab
in the lab everything was workig fine but once moved to thr production nothing works
i have sets up like this
LAN------7513----PIX----router----internet
LAn as 10.0.0.0 address 7513 as 2 ip address primary and seconday on LAN side Fastethernet(one 10.0.0.0 and another 170.15.x.x
WAN side fastethernet i have 170.x.x.x , iCan ping this address from my LAN.
PIX inside interface 170.16.x.x and i can ping from all hosts in 10.0.0. and i can see all my users when i used sh xlate
from inside i can ping inside interface of PIX
when i used sh xlate i can see my glocal address mapped to internal address but but i cannot go out internet or i cannot ping my external interface on PIX, but from my 7513
i can ping only external interface on PIX
This is my PIX config
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 DMZ security50
nameif ethernet3 ISP2 security60
nameif ethernet4 intf4 security20
nameif ethernet5 intf5 security25
nameif ethernet6 intf6 security30
nameif ethernet7 failover security15
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pix-1
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list outside_access_in permit tcp any host 206.X.X.X eq smtp
access-list outside_access_in permit udp any host 206.X.X.X eq domain
access-list outside_access_in permit icmp any any
access-list outside_access_in deny ip any any
access-list dmz_coming_in permit icmp any any
access-list dmz_coming_in permit tcp host 206.X.X.X host any eq smtp
access-list dmz_coming_in permit tcp host 206.X.X.X host any eq www
access-list dmz_coming_in permit udp host 206.X.X.X host any eq domain
access-list 101 permit ip 170.x.x.0 255.255.255.0 206.x.x.128 255.255.255.128
pager lines 24
logging on
logging monitor errors
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 100full
interface ethernet3 100full
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
interface ethernet6 auto shutdown
interface ethernet7 100full
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
mtu ISP2 1500
mtu intf4 1500
mtu intf5 1500
mtu intf6 1500
mtu failover 1500
ip address outside 206.X.X.X 255.255.255.128
ip address inside 170.X.X.X 255.255.255.0
ip address DMZ 206.X.X.252 255.255.255.128
ip address ISP2 171.X.X.21 255.255.255.0
ip address intf4 127.0.0.1 255.255.255.255
ip address intf5 127.0.0.1 255.255.255.255
ip address intf6 127.0.0.1 255.255.255.255
ip address failover 7.7.7.7 255.0.0.0
ip audit info action alarm
ip audit attack action alarm
failover
failover timeout 0:00:00
failover poll 15
failover ip address outside 206.X.X.X
failover ip address inside 170.X.X.3
failover ip address DMZ 206.X.X.253
failover ip address ISP2 171.X.X.21
failover ip address intf4 0.0.0.0
failover ip address intf5 0.0.0.0
failover ip address intf6 0.0.0.0
failover ip address failover 7.7.7.8
failover link failover
pdm location 169.x.x.155 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 206.X.X.90-206.X.X.120 netmask 255.255.255.128
global (outside) 1 206.X.X.X
global (DMZ) 1 206.X.X.X-206.X.X.X
nat (inside) 0 access-list 101
nat (inside) 1 1 170.X.X.X 255.255.255.0
nat (inside) 1 10.0.0.0 255.0.0.0 0 0
nat (DMZ) 0 206.x.x.128 255.255.255.128 0 0
static (DMZ,outside) 206.X.X.X 206.X.X.X netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group dmz_coming_in in interface DMZ
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 206.X.X.X
route inside 10.0.0.0 255.0.0.0 170.X.X. 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
url-server (DMZ) vendor n2h2 host 206.X.X.X port 4005 timeout 5 protocol T
CP
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
http server enable
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-pptp
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:3d41e9f201f32c7fbe9ac8dbafaf863e
: end
[OK]
Re: problems connecting outside
First of all, forget about trying to ping the outside PIX interface from anything on the inside, you won't be able to do that. The PIX doesn't allow you to ping/telnet/whatever to an interface address from another interface.
Now, if you're seeing your inside users get an xlate then it looks like the PIX is doing the right thing. Everyone on the inside will get mapped to 206.X.X.90-206.X.X.120 and then a PAT address of 206.X.X.X, so you need to make sure they're valid and your ISP has actually mapped those to you. Can you ping Internet addresses from the PIX itself, it's possible ICMP's are being filtered somewhere and so your ping tests are all being blocked? Can you ping from the outside router? Can you ping the global addresses listed above from the outside router?
Bronze
Hi, if I may ask a follow-up question about trying to ping the PIX's outside interface, you mean,
TOTALLY, whatever configuration I use, it is NOT possible to ping the PIX outside interface from
any hosts inside? It was mentioned in one of the PIX tech notes that command below permits pings
from the network immediately outside the PIX:
icmp permit 200.1.1.0 255.255.255.0 echo outside
So it means I can ping any IP address on that network EXCEPT the PIX interface?
Thanks.
97
