Problems connecting with VPN
The company LAN is behind a pix 501 firewall. The employees use Cisco VPN Client 4.0 This works fine when they are connecting through dial-up, but when connecting fails when they try to connect while they are on another company LAN. The get the message: "Secure VPN Connection terminated locally by the client
Reason: The remote peer is no longer responding"
Can somebody please help me with this?
Hermod Martinsen
Re: Problems connecting with VPN
I would like to verify that the network infrastructure of the other company and your PIX 501:
Does the company setup firewall or router with ACL filter the connection client between PIX? I don't mean reachability only, it may filter certain port for VPN connection setup?
Does the company using NAT or PAT?
What PIX OS you are using in PIX 501?
I don't know anything about the network infrastructure of the other company or if they are using NAT or PAT. The company I work for are holding a presentation there TOMORROW, and are depending on that the VPN works. I know that the other company has requested help from technicians, to check if the problem is on their "side".
We are using Pix Device Manager 2.0(1) and Pix Firewall 6.2(1).
220
