Problems creating VPNs via ASDM 5.2(2) Wizard
The problem I got is that when we try to use the Wizard etc to set up a new VPN, everything seems to work ok and you fill in all of the relevant details, the issue is at the end when you commit it we get an error regarding that you can not have multiple bi directional VPNs on the same cryptomap, in this case it?s the TYPE Prioirty 200, the 200 is assigned dynamically by the wizard, and starts at 20 going up in blocks of 20, well we now have enough VPN?s configured to hit 200 and now we can not seem to add anymore, if I do it manually then I can add one in on say 10 or 12 etc.
It seems to be a bug with the Wizard more than anything.
Can anyone advise?
The OS is: Cisco Adaptive Security Appliance Software Version 7.2(2)
Device Manager Version 5.2(2)
Hardware is: ASA5400
Pat
1 REPLY
Bronze
Re: Problems creating VPNs via ASDM 5.2(2) Wizard
This problem can be solved by assigning the different line number for each remote site in the crypto map configuration.
101
