problems setting up ios certificate server
When trying to setup a ios certificate server for use with VPN authentication in run into some problems.
I do have a crypto image but im missing some command options namely:
Crypto key export and crypto pki.
Is this a problem with the ios and router I am using ?
The router is a 3620 with IK9O3S6-M 12.3(16).
Thank you in advance.
1 REPLY
Bronze
Re: problems setting up ios certificate server
I would recommend you to look at the feature set for the image you are running. Not all crypto images have certification server feature.
102
