Problems with ASDM 508 on a ASA 5510
Scott Paananen
I'm new to Cisco ASA devices, So i hope i am posting this in the right area.
Heres the problem I am  having.  I have a spare 5510 device, that I am playing around with to learn the system. I was able to get it back to factory defaults (config factory-default). When i try to access to ASDM though a webbrowser (https://192.168.1.1) I get a popup for authentication. Reading several different sites, they all claim to enter nothing, but when i do, it says that the authentication has failed. Can some one help me out?  Am i doing somethign wrong? Am i able to create a new user that i can use to login with?
The ASDM version i am using is 508, as this was never udpated. (should i update it, if so what else do i need to update on the device, and steps would be very helpful)
Thank you for your time.
Scott
Marvin Rhoads
That is an ooooold ASDM (4 years old, kind of like a Windows XP of ASDMs ). Which version you can upgrade to depends on what ASA software your system is running. However updating requires a support contract (Smartnet). Do you have that?
Aside from that, if you can get in via console ports, you should see a command in your configuration like:
     aaa authentication http console LOCAL
If not add it and a local username (conf t and then that command, then "username password privilege 15 "then "exit" and "write mem").
Try logging back into ASDM using that new username and password.
