Community Member
Problems with CA Support (SCEP)
I try to setup a simple IPsec router/router Lab with MS2K Server CA.
I have successfully installed cepsetup.exe, i have check'd out the local CA webpage which shows me the fingerprint and pw...looks fine
The problem:
If i use the command "crypto ca athenticate vpn" and the pki debug, i get the following output.
wg1r2(config)#crypto ca authenticate vpn
% Error in receiving Certificate Authority certificate: status = FAIL, cert leng
th = 0
00:14:58: CRYPTO_PKI: Sending CA Certificate Request:
GET /certsrv/mscep/mscep.dll/pkiclient.exe?operation=GetCACert&message=vpn HTTP/
1.0
00:14:58: CRYPTO_PKI: http connection opened
00:14:58: CRYPTO_PKI: HTTP response header:
HTTP/1.1 200 OK
Server: Microsoft-IIS/5.0
Date: Sat, 01 Feb 2003 18:28:29 GMT
Content-Length: 3380
Content-Type: application/x-x509-ca-ra-cert
Content-Type indicates we have received CA and RA certificates.
00:14:58: CRYPTO_PKI: Can not get name ava count
00:14:58: CRYPTO_PKI: can not decode router sub name.
00:14:58: CRYPTO_PKI: Error: Certificate, private key or CRL was not found whil
e selecting certificate chain
00:14:58: CRYPTO_PKI: WARNING: A certificate chain could not be constructed whil
e selecting certificate status
00:14:59: CRYPTO_PKI: Can not get name ava count
00:14:59: CRYPTO_PKI: can not decode router sub name.
00:14:59: CRYPTO_PKI: Error: Certificate, private key or CRL was not found whil
00:14:59: CRYPTO_PKI: WARNING: A certificate chain could not be constructed whil
00:14:59: CRYPTO_PKI: can not get decoded name
00:14:59: CRYPTO_PKI: Unable to read CA/RA certificates.
00:14:59: %CRYPTO-3-GETCARACERT: Failed to receive RA/CA certificates.
00:14:59: CRYPTO_PKI: transaction GetCACert completed
Unfortunately i can't find any docs on cco which provide a solution for this issue. On the MS Server i get some traffic, i think something with the MS Appl. is not ok. Any ideas ??
Louis
1 REPLY
Community Member
Re: Problems with CA Support (SCEP)
I have finally found the mistake.
The CA was setup as root CA and Active Directory was not installed.
175
