Problems with fwsm Version 1.1(4)
We have a new FWSM Module with Version 1.1(4).
We want to upgrade this Version and have the Problem to get connection to the MSFC.
The transfer-Vlan is configured and up on the Switch, the MSFC and declared as a firewall-vlan, with set vlan 700 firewall-vlan 8.
Where Module 8 is the Firewall-Module.
We use CatOs and IOS.
How can i get a connection to the MSFC for the upgrade Process.
1 REPLY
Anonymous
N/A
Re: Problems with fwsm Version 1.1(4)
I think the following configuration may rectify your problem.
(1) clear the vlan on the MSFC, and reload it
(2) "clear config "slotn o where MSFC resides" on switch to remove all the config for FWSM
(3) remove the secure vlan
(4) unplug FWSM
(5) after MSFC is up, plug FWSM back and reconfig everything
I think the key is "clear config MSFC slot no" and re-seat the FWSM. Here is the workaround I suggest
next time:
(1) "clear config mod#", delete the vlan on switch
(2) delete the svi interface on MSFC
(3) re-seat the FWSM (may not need)
(4) reconfig in order
115
