11-07-2003 11:58 AM - edited 02-21-2020 12:52 PM
I have clients who are using different versions Mac OS X. They are all going through routers (ie DLINK, LINKSYS, etc..) When they try to use Outlook:MAC 2001, they will receive a variety of error messages. And when they remove the routers and directly connect into their ISP (Time Warner or DSL), it works perfect. I have tested this using 4.0.2C on an eMac using 10.2.8 and a coworker tested on an iBook using Panther with the same results. It does work with all Windows products going through the same router. Has anyone had to deal with this problem? Thank you.
11-13-2003 08:18 AM
You did not mention if PAT is in use. This looks like a problem with PAT, try to see if you can experiment some scenario without PAT, if problem does not exist without PAT, I guess some routers does not support PAT.
11-13-2003 01:52 PM
I do not PAT. Unless DLink 614+ PATs by default. It does NAT. This actually worked at one time. Thanks
Dwane
