Problems with parser view
Hello.
I configured a parser view to block some commands(configure line, configure username and configure dial-peer cor) for a specific user.
The parser view is working fine untill I perform a "copy run start" or "write memory" and I reboot my router : the parser view is modified and the "blocked" commands are available for all the users...
The IOS I used is the following : c3900-universalk9-mz.SPA.152-1.T1.bin
The parser view I configured is the following :
parser view BLOCKED
secret 5 XXXXXXXXXXXXX
commands configure include-exclusive line
commands configure include-exclusive dial-peer cor
commands configure include-exclusive username
While doing a "sh run | sec parser view", I receive the following :
parser view BLOCKED
commands configure include-exclusive help line
commands configure include-exclusive help dial-peer cor
commands configure include help dial-peer
commands configure include-exclusive help username
If I do a copy run start and a reload, after the reboot, the configuration of the parser view is abnormally modified as follow :
parser view BLOCKED
commands configure include help help
commands exec include help
commands exec include terminal help
I also tried to configure another parser view for my restricted user, with 'commands configure exclude' for line, username and dial-peer cor...
The parser view for restricted user is also working fine untill I save the configuration in nvram and I do a reboot... After the reboot, I encounter the same problem...
I'm not sure if there is a bug in the IOS or if I made a mistake while configuring my parser view... Could somebody help me ?
For information, I also try to use the IOS 15.1(3)T and I had the same problem...
Thx,
H
558
