Community Member
Problems with shunning
When I try to implement shunning I get the following:
0/16/2002 14:02:15UTC E Net Device offline at address [1.1.1.1] State [Connecting] SubState [Ini
tial], resetting now.
10/16/2002 14:02:59UTC E Can not set send bufsize on socket
10/16/2002 14:02:59UTC E Can not set recv bufsize on socket
10/16/2002 14:02:59UTC E Read error [Invalid argument] fd [3]
Note** IP address was changed. Actual IP is a routeable address.
I have looked everywhere and cannot find any documentation on these errors.
Chris
Re: Problems with shunning
The error indicates that the sensor was unable to establish a connection
to the shunning device. This is most often caused by misconfiguration
of the sensor or device. This can be checked by logging in to the sensor
and manually establishing a Telnet session to the shunning device using
the IP address , username, password, and enable password with which
the sensor was configured.
(These instructions will vary slightly depending on your exact configuration.
For example, if the device is a PIX, SSH might be substituted for Telnet.)
If you are able to establish a connection manually, but the sensor is
still unable to connect, open a TAC case and I will investigate further.
Community Member
i wonder if the shunning router or pix is using one time password. how the IDS will telnet to the shunning device? is it possible?
Community Member
If the shunning router or pix authenticates to a OTP server, then the sensor, which is the end user, will obviously not be able to authenticate to the OTP server. The normal aaa options (local, ACS internal DB, etc) ought to suffice though, as router management usually doesn't use OTP anyway - OTP is more prevalent for DUN and VPN users.
If password capture is a factor, then ssh can be used (at least with the pix) for shunning to mitigate that risk.
Jeff
109
