Problems with static
sysmgr3sysmgr3
I'm trying to add a static nat to redirect an dmz ip to an inside ip on port 3389. But when I enter the line I get this error.
WARNING: real-address conflict with existing static
What can I do?
Thanks.
Here's a part of my cfg:
All IP's are fictionnal but they represent the right class and range.
global (outside) 1 interface
nat (inside) 0 access-list no-nat-vpn
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,DMZ) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
static (proxy,outside) 210.119.80.0 210.119.80.0 netmask 255.255.255.128
static (inside,DMZ) 192.168.0.0 192.168.0.0 netmask 255.255.0.0
static (inside,DMZ) 172.16.0.0 172.16.0.0 netmask 255.248.0.0
static (inside,DMZ) 210.119.82.0 210.119.82.0 netmask 255.255.255.0
static (inside,proxy) 192.168.0.0 192.168.0.0 netmask 255.255.0.0
static (inside,proxy) 172.16.0.0 172.16.0.0 netmask 255.248.0.0
static (inside,proxy) 10.0.0.0 10.0.0.0 netmask 255.0.0.0
static (inside,proxy) 210.119.82.0 210.119.82.0 netmask 255.255.255.0
static (proxy,DMZ) 210.119.80.0 210.119.80.0 netmask 255.255.255.128
static (inside,outside) 210.119.82.0 210.119.82.0 netmask 255.255.255.0
static (DMZ,outside) 210.119.81.0 210.119.81.0 netmask 255.255.255.0 tcp 0 1000
static (inside,outside) 210.119.80.243 172.18.0.84 netmask 255.255.255.255 tcp 0 1000
static (inside,outside) 210.119.80.244 172.18.0.8 netmask 255.255.255.255 tcp 0 1000
access-group outside_interface_in in interface outside
access-group proxy_interface_in in interface proxy
access-group inside_interface_in in interface inside
access-group DMZ_interface_in in interface DMZ
Chuck
6 Replies 6
jackko
Level 7
Level 7
just wondering if you may post the static statement you were trying to add.
arunsing
what is the static statement that you are entering.
sysmgr3sysmgr3
Here is the line I'm trying to add
static (inside,DMZ) tcp 210.119.81.219 3389 172.18.0.8 3389
The message "WARNING: real-address conflict with existing static" is comming because of the below self static
Subnet: 172.16.0.0
Netmask: 255.248.0.0
Host Range: 172.16.0.1 to 172.23.255.254
The above self static already cover's the IP being used in the following Port redirection:
Public IP: 210.119.81.21
Private IP: 172.18.0.8
Port: 3389
Protocol: TCP
The IP 172.18.0.8 is already covered within Host Range: 172.16.0.1 to 172.23.255.254
Now i guess you should be able to fix it...!!!
Cheers...
Prashant Chauhan.
hi prashant,
just wondering how would you resolve the issue as a cisco specialist.
Hi, don't know if it is actually documented as how it works, but I had a simlar situation, and I found the static entries were applied in a top down fashion whereby the first match was used.
With that in mind, you could (during an outage window) delete the statics, then reapply with the new one entered before the existing one..........
