Problems with the Transfer vlan between MSFC and FWSM
I wanted to use a VLAN with an IP-Adress at the MSFC2 as a transfer VLAN for the FWSM.
The MSFC should route to the outside. The FWSM is in a Multi-Context, routing Mode and
there should only be one Transfer-vlan.
The Cat6500 has CatOs and the MSFC IOS.
So i tried to set up this vlan as a firewall-vlan on the Switch Cat6500 "set vlan xxx
firewall-vlan y", but this is not possible. Does anyone know whats the Problem an how
i can solve it ?
1 REPLY
Re: Problems with the Transfer vlan between MSFC and FWSM
Following is a sample configuration and you need to create SVI on the MSFC2 to be able to route the traffic via MSFC.
Good Luck !
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/mod_icn/fwsm/fwsm_2_3/fwsm_cfg/examples.htm#wp10526
105
