Problems with vpn 4.0.x
Dear all
I have a problem with the vpn client 4.0.2 (D), 4.0.3(A). I can't use it, with a message error :
Sev=Warning/3 IKE/0xA300004B
Received a NOTIFY message with an invalid protocol id(0)
My configuration :
pix 515 E with ios 6.3.3 and vpn DES
For information, when i use the vpn client 3.5.1, i haven't problems,i can access the lan and make what i want !!
my configuration too :
sysopt connection permit-ipsec
crypto ipsec transform-set ciml_transform esp-des esp-sha-hmac
crypto dynamic-map ciml_dyn_map 10 set transform-set ciml_transform
crypto map ciml_map 10 ipsec-isakmp dynamic ciml_dyn_map
crypto map ciml_map interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup ciml_vpngroup address-pool vpn_ip_pool
vpngroup ciml_vpngroup dns-server 10.1.1.41
vpngroup ciml_vpngroup default-domain toto.tata
vpngroup ciml_vpngroup idle-time 1800
vpngroup ciml_vpngroup password ********
thanks !!
fx
Silver
Re: Problems with vpn 4.0.x
transform-set ciml_transform is using SHA for hashing, and your isakmp policy is using MD5. Try setting both to the same
The combination of DES and SHA is not supported in the later versions of the VPN client. Select either DES & MD5 or 3DES & SHA for the transform set.
102
