Problems with VPNs What ports/protocols to leave open.
I have a few different networks using different Cisco routers. In most instances I have ACLs in addition to CBACs on 2524 and 2621 routers with the FW IOS 12.05(T). I have yet to find a single document that lists what ports/protocols you need to have open to successfully initiate AND recieve VPN connections through the FW IOS. Any suggestions?
Re: Problems with VPNs What ports/protocols to leave open.
Thanks for the reply but I didn't see anything in that link about VPN traffic.
you should enable esp for ipsec and udp port 500 for isakmp in your acl. hope this helps.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/113t/113t_3/ipsec.htm
"Ensure Access Lists Are Compatible with IPSec
IKE uses UDP port 500. The IPSec ESP and AH protocols use protocol numbers 50 and 51. Ensure that your access lists are configured so that protocol 50, 51, and UDP port 500 traffic is not blocked at interfaces used by IPSec. In some cases you might need to add a statement to your access lists to explicitly permit this traffic."
175
