Product decision help...
Hi there,
I work in the SMB market, and I am looking for a product that does the following:
1)Multi-wan - I have 3 wan connections
2)Content filtering - need a hands off solution to filter web browsing
3)Policy based routing - want to be able to easily choose outbound connection based on protocol.
4)Failover/load balancing - both are needed, but failover is more important that true load balancing. Load balancing is really only a 'want'
A there a single device that will accomplish this?
I usually work on a lot of ASA's, but this just won't cut it. Need some help! Thanks!
1 REPLY
Re: Product decision help...
Only a router can do all of these. If you need help sizing, just let us know.
Hope that helps.
109
