Proper upgrade order for R to UR upgrade
I was wondering if anyone has a link to the proper upgrade order for a 515e R to 515e UR. I have the licenses and memory, but have not found a clear order for the upgrade. But this is my guess.
1 - Install 128 megs of ram
2 - Add new activation key
3 - Install VAC+ card and 4 fe card
Is this correct? Thanks,
Adam
Re: Proper upgrade order for R to UR upgrade
Hi .. yes that is correct .. from the below link perform steps 4, 6 (select no),7 and 8. Once the PIX reboots with the new activation key you can install the VAC+ or you could install the modules before renewing the license if you like too. If your current license already has at least DES enabled then the module should be recognised otherwise it will once the new license is upgraded.
I hope it helps ... please rate if it does !!!
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a008008c136.html#4703
Thanks alot, just what I needed.
91
