Protecting internal server from internal clients
Hi friends,
A PIX 515E with 7.0(5) has been installed, interfaces being 1 Inside + 1 outside.
My question is if clients and server are connected to inside interface, how do I protect the internal server from attacks by internal clients?
Do i need to place the server in the DMZ? Since I dont have enough physical interfaces, can I create a DMZ by creating a logical interface / VLAN?
The clients, server and inside interface of a firewall are connected to a single Catalyst 2950 switch running IOS.
The client and server are in the same IP subnet as well.
Thanks a lot
Gautam
Re: Protecting internal server from internal clients
If both are one the same physical interface you cannot protect your inside server without placing it at least on a VLAN. The traffic goes directly from the client to the server without beeing inspected by the Firewall.
Note that a VLAN is not as save as a physical interface,it is possible to craft packets or to sniff VLANs, but is still better to have VLANs than no control at all.
sincerely
Patrick
Silver
A better option would be to purchase a single interface FastEthernet card for your DMZ. Then you can do everything as stated above without the slight security issues posed by the crafted packets....
99
