proxy identities not supported
I'm configuring a VPN for the first time with a 1720 and an 806. Both routers are doing NAT (with an address pool). There is a router in between them, so both gateways are set to the 2 interfaces on the "middle" router. The VPN does not work. The SA's appear to be formed, though. When viewing the debug messages, the following lines appear:
01:40:12: IPSEC(validate_transform_proposal): proxy identities not supported
01:40:12: ISAKMP (0:1): IPSec policy invalidated proposal
01:40:12: ISAKMP (0:1): phase 2 SA not acceptable!
Also, further down in the debug, I get this message:
01:40:12: ISAKMP (0:1): purging node 2143726286
01:40:12: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 148.74.252.2
Can anyone explain what they mean? I can barely find any info on the proxy message... Thanks!!!
  • Other Security Subjects
1 REPLY
Re: proxy identities not supported
Proxy identities not supported means the access-lists that you are using for the interesting traffic doesn't actually match or if they do, I suspect your
nat is getting into the way of the IPSec traffic. IPSec traffic should bypass your nat, sample config is on:
http://www.cisco.com/warp/customer/707/overload_private.shtml
5868
