public IP inside
I wanted to setup a web server inside but maintain the public ip address without doing NAT. Is it possible to have a pubic IP address on the inside and not do NAT with a PIX 501. Do I have to use a static command assigning the public IP its own public IP address? Thanks for the help.
1 REPLY
Re: public IP inside
Yes you can. It's possible to use the static command with the same address for both global IP (outside) and local IP (inside).
Since you will open the door to inside with this internal web server, i'm suggesting you to protect it, at least with a host based firewall and a host based IDS and some hardening technics. Also, don't forget to update frequently the OS and all application running on it.
Ben
107
