Bronze
QM FSM error on a 3005 VPN doing LAN-to-LAN
Can anybody help me understanding these errors on a VPN 3005, configured for LAN-to-LAN. Is it a configuration issue or a Hardware issue.
60534 10/28/2002 05:16:04.220 SEV=4 IKEDBG/0 RPT=75
QM FSM error (P2 struct &0x1d07664, mess id 0x4bb56838)!
60535 10/28/2002 05:16:04.220 SEV=4 IKEDBG/65 RPT=5452 65.206.223.10
Group [65.206.223.10]
IKE QM Initiator FSM error history (struct &0x1d07664)
<state>, <event>:
QM_DONE, EV_ERROR
QM_WAIT_MSG2, EV_TIMEOUT
QM_WAIT_MSG2, NullEvent
QM_SND_MSG1, EV_SND_MSG
1 REPLY
Silver
Re: QM FSM error on a 3005 VPN doing LAN-to-LAN
You ussually get such errors when there maybe some issue with ike. If you are experiencing problems, check that the ike config is correct/matches.
If this is something that comes up every now and again on a working config, it could be a renegotiation happening, and the peers are negotiating the available ike's until it matches.
383
