Query on embroynic and max conn limit on the FWSM
Can you please explain
1. the difference in setting the embroynic and max conn limit on the static and the nat command?
2. If there is a sqlnet attack (as below) will setting the following command helped?
nat (inside) 0 ... udp <max number>
sh conn
999849 in use, 999902 most used
Network Processor 1 connections
UDP out 33.209.87.100:1434 in 100.100.119.101:1244 idle 0:01:59 Bytes 36
FLAGS -
UDP out 25.192.199.249:1434 in 100.100.119.101:1244 idle 0:01:31 Bytes 36
FLAGS -
UDP out 219.252.255.232:1434 in 100.100.119.101:1244 idle 0:00:03 Bytes 36
FLAGS -
TIA
PF
Bronze
Re: Query on embroynic and max conn limit on the FWSM
Embryonic connection limit lets you prevent a type of attack where processes are started without being completed. When the embryonic limit is surpassed, the TCP intercept feature intercepts TCP synchronization (SYN) packets from clients to servers on a higher security level. The software establishes a connection with the client on behalf of the destination server, and if successful, establishes the connection with the server on behalf of the client and combines the two half-connections together transparently. Thus, connection attempts from unreachable hosts never reach the server. The PIX firewall accomplishes TCP intercept functionality using SYN cookies.
syntax:
static [(local_ifc,global_ifc)] {global_ip | interface} {local_ip [netmask mask] |
access-list acl_name} [dns] [norandomseq] [max_conns [emb_limit]]
Thanks s.
PF
134
