Community Member
Question about Port Blocking
Is there a way that I can block A VLAN on my network from using an IP Port? If so how do I go about doing that on the router?
1 REPLY
Gold
Re: Question about Port Blocking
IP doesn't have ports.
You can use ACL's on your router to block tcp/udp ports though. We probably need more information to help you out.
Is your router internal to your network? How is NAT done? Do you use a firewall? what kind of NAT pool do you have?
105
