Question on Cisco Security Appliance Command Reference 7.1(1) page 23-44
Can somebody explain to me about static route with tunneled option?
What this mean? "all encrypted traffic that arrives on the security
appliance and cannot be routed using learned or static routes is sent to this route"
Pleasse give me a example.
hostname(config)# route outside 0 0 209.165.201.1 (tunneled) 1
You can define a separate default route for tunneled traffic along with the standard default route. When
you create a default route with the tunneled option, all encrypted traffic that arrives on the security
appliance and cannot be routed using learned or static routes is sent to this route. Otherwise, if the traffic
is not encrypted, the standard default route entry is used. You cannot define more than one default route
with the tunneled option; ECMP for tunneled traffic is not supported.
Silver
Re: Question on Cisco Security Appliance Command Reference 7.1(1
The options include
Speed
Duplex
MTU
IP fragmenatation policy
Hi, I think you are misunstood my question.
I asked what's the difference between
hostname(config)# route outside 0 0 209.165.201.1 1
and
hostname(config)# route outside 0 0 209.165.201.1 tunneled 1
Neex example to explain it.
102
