Community Member
Question on csc-ssm and aip-ssm modules in the ASA5500
Is it true that both the csc-ssm and aip-ssm modules can't co-exist in the ASA5500 device at the same time??
One more question is there are sample config/example on the cisco site using the intra-interface keyword command involving NON IPSEC TRAFFIC
1 ACCEPTED SOLUTION
Re: Question on csc-ssm and aip-ssm modules in the ASA5500
Yes, csc-ssm and aip-ssm modules can't co-exist in the ASA5500 as only 1 slot is available to install them. You have to choose one.
See the slot availability at:
http://www.cisco.com/en/US/products/ps6120/products_installation_guide_chapter09186a00805ad777.html#wp1043723
ASA5505 & ASA5550 - no slot for csc/aip
ASA5510/20/40 - 1 empty slot each
Cisco sample config for intra-interface om non-VPN:
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a0080734db7.shtml
AK
AK
Community Member
AK
thanks alot ... yeah that information was good enuff
177
