Question on csc-ssm and aip-ssm modules in the ASA5500
Is it true that both the csc-ssm and aip-ssm modules can't co-exist in the ASA5500 device at the same time??
One more question is there are sample config/example on the cisco site using the intra-interface keyword command involving NON IPSEC TRAFFIC
1 ACCEPTED SOLUTION
Re: Question on csc-ssm and aip-ssm modules in the ASA5500
It is true that both the csc-ssm and aip-ssm modules can't co-exist in the ASA5500 device at the same time.
There isn't a sample configuration availavle onsite yet. However, apart from the same-security command, you would need the regular translation rule to pass the traffic. Also, due to the stateful nature, it only allows unidirectional traffic. Eg:
nat (inside) 10 192.168.1.0 255.255.255.0
global (inside) 10 interface
global (ouotside) 10 interface(not required though)
Sincerely,
~AJ
Sincerely,
~AJ
AJ
Thanks alot
159
