Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
"no translation group found for tcp src dmz..."?
Just when you think you've got it sussed...
I'm not getting on too well with PIX OS 7.0.x. To try and get back to basics, I've created a short config in the cli. Essentially, its a 3 legged config; inside, outside, dmz.
All I really want to do is:
1)Allow any to talk to a host in the dmz on http.
This works fine.
2)Allow the dmz host to talk to a host on the inside on http.
This doesnt. Message I get is (seen in ASDM):
"no translation group found for tcp src dmz:SG01/1262 dst inside:inside-web-server/80".
Anyone have any ideas? My names, static, acl, access-group: all look fine. I've cleared xlate a gazillion times.
Is the fact that both the acl allowing access from the outside to the dmz host and the acl allowing the dmz host access
to the inside host are both http breaking things?
Config is below:
PIX Version 7.0(4)
hostname pixfirewall
domain-name
enable password
names
name 192.168.168.11 SG01 description SG01's internal ip address
name 10.100.10.20 inside-web-server description internal web server ip address
name (xxx.xxx.xxx.xxx) outside-web-server description aone of my publics is a web server
interface Ethernet0
description The outside interface
nameif outside
security-level 0
ip address (xxx.xxx.xxx.xxx) (255.255.255.240)
interface Ethernet1
nameif inside
security-level 100
ip address 10.100.10.0 255.255.0.0
interface Ethernet2
description The dmz interface
nameif dmz
security-level 50
ip address 192.168.168.1 255.255.255.0
passwd
ftp mode passive
access-list outside_access_in remark Added an 'access rule' permitting any source/any port on the outside to access SG01
access-list outside_access_in remark as long as its http traffic.
access-list outside_access_in extended permit tcp any host outside-web-server eq www
access-list dmz_access_in remark Test rule, to allow SG01 to talk to inside-web-host
access-list dmz_access_in remark as long as its http traffic.
access-list dmz_access_in extended permit tcp host SG01 host inside-web-server eq www
pager lines 200
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
icmp permit any inside
asdm image flash:/asdm
no asdm history enable
arp timeout 14400
static (dmz,outside) outside-web-server SG01 netmask 255.255.255.255
static (inside,dmz) SG01 inside-web-server netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 (next hop) 1
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Re: "no translation group found for tcp src dmz..."?
I think this is because you already used the SG01's IP (192.168.168.11) for a host in DMZ.
To allow DMZ host to talk to inside/internal segment host, you need to use unused IP, e.g:
static (inside,dmz) 192.168.168.100 inside-web-server netmask 255.255.255.255
*assuming 192.168.168.100 is a free IP
or use "static (inside,dmz) 10.100.10.0 10.100.10.0 netmask 255.255.255.0 -> allow DMZ to access inside hosts using inside host's physical/original IP.
Apply ACL to allow specific TCP/UDP services.
BTW, your inside interface should use host IP, e.g 10.100.10.1, instead of network ID of "10.100.10.0 255.255.255.0"
Rgds,
AK
Thanks AK, I'll try that out-
regards,
Gary
1506
