RADIUS-error on 3640 using MS IAS
Hi everyone,
I'm having trouble with MS IAS and a 3640 for dial-in. The user is
authenticated fine - but authorizatin fails with:
"RADIUS: unrecognized Microsoft VSA type 10"
"RADIUS: no appropriate authorization type for user"
From what I've found these would be the case when the attributes
Service-Type=Framed and Framed-Protocol=PPP are missing from the
RADIUS-server. These setting are however there in the default dial-in
profile in MS IAS.
Any thoughts??
Config and debug below.
Thanks !
Johan
3w6d: %ISDN-6-CONNECT: Interface Serial1/0:2 is now connected to 858714800
3w6d: %LINK-3-UPDOWN: Interface Async30, changed state to up
3w6d: As30 PPP: Treating connection as a dedicated line
3w6d: As30 AAA/AUTHOR/FSM: (0): LCP succeeds trivially
3w6d: AAA/ACCT/DS0: channel=2, ds1=0, t3=0, slot=1, ds0=16777218
3w6d: As30 MS-CHAP: O CHALLENGE id 6 len 22 from "Cisco-RAS"
3w6d: As30 MS-CHAP: O CHALLENGE id 7 len 22 from "Cisco-RAS"
3w6d: As30 MS-CHAP: I RESPONSE id 7 len 70 from "INSIDE\rasdialin"
3w6d: AAA: parse name=Async30 idb type=10 tty=30
3w6d: AAA: name=Async30 flags=0x11 type=4 shelf=0 slot=0 adapter=0 port=30
chann
el=0
3w6d: AAA: parse name=Serial1/0:2 idb type=13 tty=-1
3w6d: AAA: name=Serial1/0:2 flags=0x55 type=1 shelf=0 slot=1 adapter=0
port=0 ch
annel=2
3w6d: AAA/MEMORY: create_user (0x615B78A0) user='INSIDE\rasdialin'
ruser='NULL'
port='Async30' rem_addr='858714800/0858765920' authen_type=MSCHAP
service=PPP pr
iv=1 initial_task_id='0'
3w6d: RADIUS: ustruct sharecount=0
3w6d: Radius: radius_port_info() success=1 radius_nas_port=1
3w6d: RADIUS: Initial Transmit Async30 id 43 172.16.16.252:1645,
Access-Request,
len 165
3w6d: Attribute 4 6 AC1010FB
3w6d: Attribute 5 6 0000001E
3w6d: Attribute 61 6 00000000
3w6d: Attribute 1 18 494E5349
3w6d: Attribute 30 12 30383538
3w6d: Attribute 31 11 38353837
3w6d: Attribute 26 16 000001370B0A64BA
3w6d: Attribute 26 58 0000013701340701
3w6d: Attribute 6 6 00000002
3w6d: Attribute 7 6 00000001
3w6d: RADIUS: Received from id 43 172.16.16.252:1645, Access-Accept, len 119
3w6d: Attribute 6 6 00000004
3w6d: Attribute 25 32 5F1B06C0
3w6d: Attribute 26 40 000001370C224097
3w6d: Attribute 26 15 000001370A090749
3w6d: As30 AAA/AUTHOR/LCP: Authorize LCP
3w6d: As30 AAA/AUTHOR/LCP (548968306): Port='Async30' list='' service=NET
3w6d: AAA/AUTHOR/LCP: As30 (548968306) user='INSIDE\rasdialin'
3w6d: As30 AAA/AUTHOR/LCP (548968306): send AV service=ppp
3w6d: As30 AAA/AUTHOR/LCP (548968306): send AV protocol=lcp
3w6d: As30 AAA/AUTHOR/LCP (548968306): found list "default"
3w6d: As30 AAA/AUTHOR/LCP (548968306): Method=radius (radius)
3w6d: RADIUS: unrecognized Microsoft VSA type 10
3w6d: RADIUS: no appropriate authorization type for user.
3w6d: As30 AAA/AUTHOR (548968306): Post authorization status = FAIL
3w6d: As30 AAA/AUTHOR/LCP: Denied
3w6d: As30 MS-CHAP: O FAILURE id 7 len 24 msg is "Authorization failed"
3w6d: AAA/MEMORY: free_user (0x615B78A0) user='INSIDE\rasdialin'
ruser='NULL' po
rt='Async30' rem_addr='858714800/0858765920' authen_type=MSCHAP service=PPP
priv
=1
3w6d: %ISDN-6-DISCONNECT: Interface Serial1/0:2 disconnected from 858714800
, c
all lasted 25 seconds
version 12.2
no parser cache
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Cisco-RAS
no logging rate-limit
aaa new-model
aaa authentication login default group radius local
aaa authentication login NO_AUTHEN none
aaa authentication ppp default if-needed group radius local
aaa authorization network default group radius
enable secret xxxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxxxxxxx
modem country mica sweden
ip subnet-zero
no ip domain-lookup
no ip dhcp-client network-discovery
isdn switch-type primary-net5
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1/1
interface FastEthernet1/0
ip address 172.16.16.251 255.255.240.0
duplex auto
speed auto
interface Serial1/0:15
ip unnumbered FastEthernet1/0
encapsulation ppp
dialer pool-member 1
isdn incoming-voice modem
no fair-queue
ppp callback accept
ppp authentication pap
ppp multilink
interface Group-Async1
encapsulation ppp
async mode interactive
peer default ip address dhcp
ppp callback accept
ppp authentication ms-chap chap
group-range 1 30
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ppp callback accept
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.16.254
no ip http server
dialer-list 1 protocol ip permit
radius-server host 172.16.16.252 auth-port 1645 acct-port 1646 key 7
121A0C04110
402013E3C2B3A383C2C14
radius-server retransmit 3
line con 0
exec-timeout 0 0
password xxxxxxxxxx
logging synchronous
login authentication NO_AUTHEN
line 1 30
no exec
modem InOut
modem autoconfigure type mica
rotary 1
transport preferred telnet
transport input all
autoselect ppp
line aux 0
password xxxxxx
line vty 0 4
exec-timeout 0 0
password xxxxxxxx
end
isco Internetwork Operating System Software
IOS (tm) 3600 Software (C3620-I-M), Version 12.2(2)T, RELEASE SOFTWARE
(fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 02-Jun-01 14:56 by ccai
Image text-base: 0x600089A8, data-base: 0x60AA0000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE
SOFTWARE (f
c1)
ROM: 3600 Software (C3620-I-M), Version 12.2(2)T, RELEASE SOFTWARE (fc1)
Cisco-RAS uptime is 3 weeks, 6 days, 17 minutes
System returned to ROM by reload
System image file is "flash:c3620-i-mz.122-2.t.bin"
cisco 3620 (R4700) processor (revision 0x81) with 26624K/6144K bytes of
memory.
Processor board ID 26387501
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
MICA-6DM Firmware: CP ver 2720 - 5/30/2000, SP ver 2720 - 5/30/2000.
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
31 Serial network interface(s)
30 terminal line(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
1 REPLY
Re: RADIUS-error on 3640 using MS IAS
Looks like the service-type configured for this user is "callback" (service-type=4)..Now router didn't like the attribute number 25 and 28
Do you want to do callbcak for this user?
So you need to investigate in the RADIUS server (under the user/group profile) about attribute 25 (class) and Vendor Specific Attribute (VSA) which may have configured for this user. You need to configure the VSA for cisco..
Try to gather the profile for this user from radius server.
Here is the link which may be helpful for callback using cisco router, thru radius
http://cco/warp/public/480/pppcallback_rad.html
350
