Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Reasons for Login Failed to NAC in L3OOB
I am implementing NAC in L3OOB envirnment, setup is upgradeed to 4.5, my NAC expertise is best effort.
I assumed I have finished building the basic setup to test authenticating CCA agent using local DB, but on entering user credential to the pop-up, I get "Login Failed" with no identified reason.
I just wonder if there is a link to a document shows the mandatory steps must be done before assuming NAC solution is ready for testing.
Definite, it would be grateful if you have a hint what could be the reason for login failure.
Sami
1 REPLY
Gold
Re: Reasons for Login Failed to NAC in L3OOB
125
