I recently upgraded our 515E to 7.2.1 (which wasn't exactly smooth) and I am now getting the following two messages:
INFO: Outside address overlap with static NAT configuration
INFO: Global address overlaps with NAT exempt configuration
The second message only appears on startup but the first appears when you modify the exempt acl. I have looked through the configs many many times and can't find the problem. Has anyone else had these messages before and what was the solution? Thanks for your help.
