Reg:web servers
Dear sir,
we have 4 webservers for this we r planing to take firewall for this webservers which firewall is the best.
iam planing to take asa5510 is suitable for this application.
srini
Re: Reg:web servers
Hi, you are not giving much details requirements other than 4 webservers, you tell me what is best for your requirements by looking at the bellow table.
ASA model comparison and specification.
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Rgds
Jorge
Re: Reg:web servers
Dear sir,
Thanks for ur reply.
This firewall is required for protecting SQL server hosting multiple
database on it and will be accessed by 200+ clients(not concurrent).
Firewall will be connected directly to sql server through LAN port.
512Kbps internet bandwidth will be taken for accessing through public
network.
plz suggest me the best firewall.
regards
srini
Re: Reg:web servers
asa5510 firewall should provide you with what you need.
Rgds
Jorge
113
