Regarding Static command
If we are configuring a site-to-site
VPN tunnel between two pix-pix or pix-to-router or pix-VPN Conentrator 3000
take that we are cofiguring acl for intrestiing traffic in pix 515
do we need to configure static
even VPN tunnel is configured
like Ex:
access-list VPN permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
here local network 10.1.1.0
remote Network 10.2.2.0
VPN config
ex:
crypto map 10 VPN match address VPN
static (inside,outside) 10.1.1.5 10.1.1.5 netmask 255.255.255.0
my Question is here static is necessary event the traffic is encrypted beween two sites
thanks
gopi
Re: Regarding Static command
Hi Gopi,
no, you wont need a static. The acl will catch the 'interesting' traffic and pass this to the crypto map.
HTH-
regards,
Gary
Im assuming that both PIX firewalls have some form of NAT configured for internet access. You must have a NAT 0 statement to ensure that the traffic is not NAT'd and sent over the vpn tunnel.
access-list nonat permit ip 10.1.1.0 255.255.255.0 10.2.2.0 255.255.255.0
nat (inside) 0 access-list nonat
NOTES: 10.1.1.0 local and 10.2.2.0 is remote
you would have to do this on both sides of the vpn tunnel for PIXs
Hope this helps...
Double A-Ron
93
