Remote Access VPN + gateway through pix = Deny inbound (No xlate) [HELP]
I am trying to set up my first VPN.
I want to make a remote access VPN where remote clients
on the road can VPN into a Pix and remote gateway through
the PIX out to the Internet.
remote PC <-> VPN through Internet->PIX<-Pix Lan and access outside Internet access <->
My PIX configuration below allows remote access clients
using Windows 2000 and the 2000 VPN software in Win 2000
to remotely connect up to my PIX. The remote VPN client
sees everything on the inside of my PIX Lan. The remote
VPN client however can’t remote gateway out of my pix to
the Internet.
When they try, I get logs showing:
106011: Deny inbound (No xlate) tcp src outside:192.168.1.1/2286 dst outside:207.46.104.20/80
Can somebody show me what I need to do so that a remote access
client can VPN into my PIX and then have the ability to get
out to the Internet as if they were directly on a PC on my PIX Lan?
Thank you in advance
Tom Jones
Below is my current PIX configuration:
NOTES:
PIX-501 Cisco PIX Firewall Version 6.1(1)
* IP information 10.10.10.x = Outside Internet real IP addresses
* IP information 192.168.77.x = Pix inside LAN
* IP information 192.168.1.x = what remote-access clients get when they connect
* I am using only local authentication at this time
PIX# show config
: Saved
PIX Version 6.1(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable xxxxxxxxxxxxxxxx xxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxx encrypted
hostname PIXTEST
domain-name pixtest.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list acl_out permit tcp any host 10.10.10.83 eq www
access-list acl_out permit icmp any any
access-list acl_out permit udp any host 10.10.10.82 eq tftp
access-list acl_vpn permit ip any any
access-list 101 permit ip 192.168.77.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 24
logging on
logging timestamp
logging buffered informational
logging trap debugging
logging history debugging
interface ethernet0 10baset
interface ethernet1 10full
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 10.10.10.94 255.255.255.248
ip address inside 192.168.77.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool bigpool 192.168.1.1-192.168.1.254
pdm history enable
arp timeout 14401
global (outside) 1 interface
nat (inside) 0 access-list 101
! - - Note I have tried changing nat (inside) 1
nat (inside) 1 192.168.77.0 255.255.255.0 75 75
static (inside,outside) 10.10.10.83 192.168.77.245 netmask 255.255.255.255 0 0
static (inside,outside) 10.10.10.82 192.168.77.254 netmask 255.255.255.255 0 0
access-group acl_out in interface outside
route outside 0.0.0.0 0.0.0.0 10.10.10.93 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server disable
http 192.168.77.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local bigpool outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn3000-all address-pool bigpool
vpngroup vpn3000-all dns-server 192.168.77.245
vpngroup vpn3000-all default-domain pixtest.com
vpngroup vpn3000-all idle-time 1800
vpngroup vpn3000-all password ********
telnet 192.168.77.0 255.255.255.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 60
vpdn group 1 accept dialin pptp
vpdn group 1 ppp authentication pap
vpdn group 1 ppp authentication chap
vpdn group 1 ppp authentication mschap
vpdn group 1 ppp encryption mppe 40
vpdn group 1 client configuration address local bigpool
vpdn group 1 pptp echo 60
vpdn group 1 client authentication local
vpdn username remoteuser password remotepassword
vpdn enable outside
dhcpd address 192.168.77.10-192.168.77.20 inside
dhcpd dns 192.168.77.245
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain pixtest.com
dhcpd enable inside
terminal width 80
Cryptochecksum:85eec5ada264eb9f0bd39215324f09ea
PIX#
Re: Remote Access VPN + gateway through pix = Deny inbound (No x
This is not possible with the Pix. PIX will never send a packet out of the same interface from where it received it.
You can enable Split Tunneling for the group connecting using Cisco VPN Client and this will allow the users to access the lan behind the Pix and also access the internet.
Arul
Errrrr... What a big set back for me...... re:
"...PIX will never send a packet out of the same interface from where it received it..."
Does anybody know if a Cisco 2600 class router with Nat enabled will allow a remote access VPN connection where the remote VPN user may gateway out to the Internet throught the IOS router (and follow other routes in the 2600)?
I think I may of made a small $$$ mistake thinking the Cisco PIX would handle my VPN needs.
errr Tom Jones
147
