remote access vpn problem
melvynbrown
have set up a small home lab to test site to site and remote access vpn
on a cisco 1700 router where the remote office router (BRANCH) gets its
outside address dynamically assigned see attacment's for HQ router config
and network layout
whilst the site to site vpn works perfectly i have come across a problem
with the remote access side of things i can form a tunnel from the remote
access client to the HQ router and once the tunnel is up can connect with the
web server at 192.168.1.2 without any problems,but i can't access the shared
folders on the file server at 192.168.1.3 nor can i ping any addresses behind
the router.
this i can't figure out as there are no access-lists to filter the traffic
its not a share permission problem as the ntfs and share permissions on
the shared folders are set to everyone full control and the computer has
been configured with the correct default gateway.
has anybody any idea what could be causing this to happen?
yours completely stumped
Melvyn Brown
ps have run debug crypto ipsec and debug crypto isakmp commands when i try
to connect to the shared folders but there is no output from the router.
