Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Remote access VPN to Inside and DMZ
Is it possible to configure PIX for easy VPN server( over internet forming a tunnel to outside interface of PIX ). for Cisco VPN client, which can be used to access inside as well as dmz computers. When specifying ip local pool if pool is from inside ip range ( one of which will be used to assign ip address to remote cisco vpn client ) with this ip address range, can client will be able access both interfaces computer ? ( inside and dmz )
Subodh
1 REPLY
Silver
Re: Remote access VPN to Inside and DMZ
PIX Firewall can function as an Easy VPN Server in relation to an Easy VPN Remote device, such as a PIX 501 or PIX 506/506E, or in relation to Cisco VPN software clients. When used as an Easy VPN Remote device, the PIX Firewall can push VPN configuration to the VPN client or Easy VPN Remote device, which greatly simplifies configuration and administration.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a00800eb72d.html
264
