Community Member
Remote administration with VPN
Two sites are connected with a VPN connection (router to router).
I want use PCANYWHERE to administrate a NT Server trought VPN.
Which ports need to be permit to make this remote administration ?
Is there any restriction ?
Thank you for your response.
Community Member
Re: Remote administration with VPN
You'll need to allow ports tcp/5631 and udp/5632 inbound where the server resides.
Community Member
Assuming your VPN is over the Internet, and encrypted , all LAN to LAN traffic would typically be allowed to pass, unless your mapped an ACL.
I set up PC anywhere to work on a router, using an extended access-list on the serial interface (inbound). I know it was UDP, and the port was low.
Simply write an extended access-list, apply it to your serial interface, and log all traffic
access-list 101 permit any any log
Then find the PC Anywhere intiated connection as it pass the access-list. This is the easiest was to find what ports it's using. Also, on Windows based by, connect to a host using PC anywhere.
The go to a command prompt, and type 'netstat -an |more' and you can see this on the PC also.
good port listing on the url above.
