Community Member
Remote desktop through VPN
I have a PIX 501, the VPN is working now. I can establish my VPN connection, but i can't access the servers on the other side. I need to do remote desktop connection and Web(atleast).I think the problem is with my access-list access-group, maybe my route too. Here's what i have now...can anyone help me out please?
access-list acl_out permit icmp any any
access-list 101 permit ip
access-list 102 permit ip
global (outside) 1 interface
nat (inside) 1 0 0
access-group acl_out in interface outside
If you need more info let me know.
Re: Remote desktop through VPN
Can you post your full configuration please (taking out any sensitive info)
Thanks / Jay
Community Member
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ********** encrypted
passwd ********** encrypted
hostname PIX
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
pager lines 21
icmp permit any outside
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside
ip audit info action alarm
ip audit attack action alarm
ip local pool vpnuser
pdm location inside
pdm location inside
pdm logging informational 100
pdm history enable
arp timeout 14400
nat (inside) 1 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
fragment chain 1
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool vpnuser
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
telnet timeout 5
ssh outside
ssh timeout 5
console timeout 0
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname **********
vpdn group pppoe_group ppp authentication pap
vpdn username ********** password ********* store-local
dhcpd address inside
dhcpd dns
dhcpd lease 1048575
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username user01 password ********** encrypted privilege 15
terminal width 80
try adding
nat (inside) 0 access-list 102
also apply "vpngroup vpn3000 split-tunnel 101"
Community Member
Great, thanks for the help guys, i'll try that out tomorrow, i'll let you know the results.
Thanks again
