remote peer no longer responding using Cisco VPN client 4.x
Help - new to vpn - I have user with XPHome - when attempting to connect he gets an error "secure vpn connection is terminated. Remote peer is no longer responding."
Connecting to 1700 series router in main office.
I have another laptop with 2000 working fine through the same location.
Any help is appreciated.
Silver
Re: remote peer no longer responding using Cisco VPN client 4.x
Looks like messages are being logged because the remote side is sending an acknowledgement for an SA. Have you cleared out that SA or the unit had been reset, etc on your side? Please make sure that the group is correctly configured in the concentrator. Here is a link with this sample configuration:
http://www.cisco.com/warp/public/471/ipsec_3000.html
Hi umedryk,
Referring the document, it does not mention anything configurations at the router connecting to the VPN Concentrator. Is there any ACL or Static Routes need to be configured at the router?
285
