01-14-2004 11:20 AM - edited 03-09-2019 06:08 AM
Okay, I have a PIX 506E at my HQ. At the HQ we have 2 subnets, 192.168.5.0/24 and 192.168.2.0/24. We also have a remote site that is connected via an IPSec tunnel on a VPN 3000, 192.168.0.0/24. When remote users connect from the field, they connect via PPTP, and get assigned addresses from a local pool of 192.168.6.0/24. The remote users can access resources on 192.168.5.0/24 and 192.168.2.0.24. The remote site can access resources on both 192.168.5.0/24 and 192.168.2.0/24. The problem is, remote users need to access the remote site as well, but they cannot. Here is my config (10.x.y.z represents public network addresses):
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password MyEncryptedPassword encrypted
passwd MyEncryptedPassword encrypted
hostname pixfirewall
domain-name corporate.local
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 120 permit ip 192.168.6.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list 100 permit ip 192.168.5.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 100 permit ip 192.168.2.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list 100 permit ip 192.168.6.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 permit ip 192.168.0.0 255.255.255.0 192.168.6.0 255.255.255.0
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list nonat permit ip 192.168.2.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list nonat permit ip 192.168.2.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list nonat permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list nonat permit ip 192.168.5.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat permit ip 192.168.5.0 255.255.255.0 192.168.0.0 255.255.0.0
access-list nonat permit ip 192.168.0.0 255.255.255.0 192.168.6.0 255.255.255.0
access-list nonat permit ip 192.168.2.0 255.255.255.0 192.168.6.0 255.255.255.0
access-list nonat permit ip 192.168.5.0 255.255.255.0 192.168.6.0 255.255.255.0
access-list nonat permit ip 192.168.6.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list nonat permit ip 192.168.6.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list nonat permit ip 192.168.6.0 255.255.255.0 192.168.5.0 255.255.255.0
pager lines 24
logging on
logging standby
logging console emergencies
logging monitor emergencies
mtu outside 1500
mtu inside 1500
ip address outside w.x.y.130 255.255.255.128
ip address inside 192.168.5.6 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool remote 192.168.6.1-192.168.6.254
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (outside) 0 access-list 120
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 68.248.179.131 192.168.5.192 netmask 255.255.255.255 0 0
conduit permit tcp host 68.248.179.131 eq smtp any
conduit permit tcp host 68.248.179.131 eq www any
conduit permit tcp host 68.248.179.131 eq https any
conduit permit tcp host 68.248.179.131 eq ssh any
conduit permit tcp host 68.248.179.131 eq domain any
conduit permit udp host 68.248.179.131 eq domain any
route outside 0.0.0.0 0.0.0.0 w.x.y.129 1
route inside 192.168.2.0 255.255.255.0 192.168.5.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server radius-authport 1812
aaa-server radius-acctport 1813
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
aaa-server sso protocol radius
aaa-server sso (inside) host 192.168.5.3 MySecretPhrase timeout 15
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set ukset esp-3des esp-md5-hmac
crypto map ukmap 10 ipsec-isakmp
crypto map ukmap 10 match address 100
crypto map ukmap 10 set peer 10.1.1.210
crypto map ukmap 10 set transform-set ukset
crypto map ukmap interface outside
isakmp enable outside
isakmp key ******** address 10.1.1.210 netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
telnet timeout 5
ssh 192.168.5.0 255.255.255.0 inside
ssh timeout 10
console timeout 0
vpdn group remote accept dialin pptp
vpdn group remote ppp authentication mschap
vpdn group remote ppp encryption mppe 40
vpdn group remote client configuration address local remote
vpdn group remote client configuration dns 192.168.5.194
vpdn group remote client authentication aaa sso
vpdn group remote pptp echo 60
vpdn enable outside
terminal width 80
01-14-2004 05:05 PM
You can't do this with the PIX. The PIX won't send traffic back out the same interface it came in on, which includes traffic coming via PPTP and then going back out via IPSec.
Only way to do it would be to set up a separate interface for your L2L tunnels, and have your PPTP users come in on the outside interface (as seen here http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080103ed0.shtml), but since you have a 506 with only two interfaces you can't do this either.
Sorry, no way around it currently. V7 software due out later this year will resolve this , but for the moment you can't do it. You'll have to get your clients to connect directly to the other site.
01-14-2004 06:15 PM
Well, I have a 515E that I am about to replace the 506E with, and the 506E will go to another remote site. The 515E has 3 ports, but I was going to use that for a DMZ for my WLAN. I guess I could get another card and upgrade to the UR version of the PIX OS later.
01-14-2004 08:07 PM
If you use Pix version 6.3, you can create logical interfaces with dot1q encapsulation. This means you can create two "outside" interfaces and terminate the VPNs on different interfaces to allow spoke-to-spoke traffic. Note that this feature is only available on 515 and up. (not 506 or 501).
The R version of the Pix allows for 5 total interfaces. Maximum of 3 can be physical.
01-15-2004 02:40 AM
That is great. You just saved me from spending more of my budget. Now I will be able to get a modular switch later in the year :) Do you happen to have an example of this configuration?
01-16-2004 03:38 PM
This is the closest example Cisco has. It really isn't any different if you ignore the interface names. The functional part important is that tunnel traffic from one interface can leave and go out another tunnel interface.
01-22-2004 12:32 PM
Well, I tried to assign the IPs to the 2 interfaces on the outside, and it says I cannot assign an ip that is on the same subnet as another interface
01-22-2004 02:46 PM
I looked at the config again, from the first example, and there are two subnets between the router and the pix, so I am going to do some dot1q with the 1721 router I have as well, and all will be good. I will report success if it is successful.
01-22-2004 03:00 PM
Like a router, a firewall cannot have two interfaces on the same subnet. How would it make decisions on how to forward traffic?
The two interfaces must have different subnets. This can be accomplished by splitting your current public subnet or even by using private addresses and NAT. PPTP will work with NAT but not PAT.
01-24-2004 05:57 PM
Okay, I created two subnets, implemented dot1q trunking, and everything is cool. As per the first config mentioned, I setup a static route for the other ipsec end-point to be routed out that interface rather than the default route, but I am unable to reach the host, I have a call into TAC.
01-26-2004 09:58 AM
How are you handling NAT? Don't forget that you'll need new NAT entries for the new interface and destionations, probably a [nat 0] statement.
Are you using [sysopt permit-pptp]? If not, you'll also need ACL entries on that interface.
Do you have overlapping subnets?
Do the far side know to use the tunnel for the traffic in question?
01-26-2004 10:37 AM
Okay, there is success. The biggest issues to keep in mind here is that you have two "outside" interfaces. These two interfaces are on different subnets, both in the public address space, attached to the Internet. I resolved this by using dot1q between my router and pix, this allowed logical interfaces. The second thing that I had to worry about was routing. The second "outside" interface could not ping anywhere outside its subnet. I had to create a route to the network(s) that need(s) access to the interface for tunnel termination. Lastly, allowing remote users to access the data on the other networks attached via IPSec tunnels... You have to create a nat 0 for you "outside" interface, but do not name it "outside" because you may need to raise the security of that interface. Anyhow, all is working, in an extremely complex setup, as I am implementing VLANs and dot1q, and RADIUS for authentication, on top of everyting in that config. Thanks to all that helped.
