Remote VPN connection drop intermittently.
Cisco VPN client remote VPN to Pix520
V6.3.4. A number of users from differnt location is having the same problem. i.e intermittently get disconnected and having to reconnect again. The time before disconnection can varies b/t 15 minutes up to just over 1 hour.
Here is the log from both the Pix and CVPN client captured when it happened.
IP address had been masked as XXX and YYY.
Logg from Pix Firewall running 6.3.4
2006-09-30 10:57:45 Local4.Info FWUDCVPN01 %PIX-6-602302: deleting SA, (sa) sa_dest= XXX.202.141.120, sa_prot= 50, sa_spi= 0xf8cdd4fc(4174238972), sa_trans= esp-des esp-md5-hmac , sa_conn_id= 6
2006-09-30 10:57:45 Local4.Info FWUDCVPN01 %PIX-6-602302: deleting SA, (sa) sa_dest= YYY.106.17.33, sa_prot= 50, sa_spi= 0x21bf705d(566194269), sa_trans= esp-des esp-md5-hmac , sa_conn_id= 5
2006-09-30 10:57:45 Local4.Info FWUDCVPN01 %PIX-6-602203: ISAKMP session disconnected (local XXX.202.141.120 (responder), remote YYY.106.17.33)
2006-09-30 10:57:46 Local4.Debug FWUDCVPN01 %PIX-7-702202: ISAKMP Phase 1 delete sent (local XXX.202.141.120 (responder), remote YYY.106.17.33)
Log from Cisco VPN client version 4.8
907 10:57:31.314 09/30/06 Sev=Info/6 IKE/0x63000055
Sent a keepalive on the IPSec SA
908 10:57:41.329 09/30/06 Sev=Info/6 IKE/0x63000055
909 10:57:44.483 09/30/06 Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = XXX.202.141.120
910 10:57:44.483 09/30/06 Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK INFO *(HASH, DEL) from XXX.202.141.120
911 10:57:44.483 09/30/06 Sev=Info/5 IKE/0x63000018
Deleting IPsec SA: (OUTBOUND SPI = F8CDD4FC INBOUND SPI = 21BF705D)
912 10:57:44.483 09/30/06 Sev=Info/4 IKE/0x63000049
Discarding IPsec SA negotiation, MsgID=744F6167
913 10:57:44.844 09/30/06 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0x5d70bf21
914 10:57:44.844 09/30/06 Sev=Info/4 IPSEC/0x6370000C
Key deleted by SPI 0x5d70bf21
915 10:57:44.844 09/30/06 Sev=Info/4 IPSEC/0x63700013
Delete internal key with SPI=0xfcd4cdf8
916 10:57:44.844 09/30/06 Sev=Info/4 IPSEC/0x6370000C
Key deleted by SPI 0xfcd4cdf8
917 10:57:45.475 09/30/06 Sev=Info/5 IKE/0x6300002F
918 10:57:45.475 09/30/06 Sev=Info/4 IKE/0x63000014
919 10:57:45.475 09/30/06 Sev=Info/5 IKE/0x6300003C
Received a DELETE payload for IKE SA with Cookies: I_Cookie=51920D8301E57492 R_Cookie=0DC8CA40233A804A
920 10:57:45.475 09/30/06 Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion (I_Cookie=51920D8301E57492 R_Cookie=0DC8CA40233A804A) reason = PEER_DELETE-IKE_DELETE_UNSPECIFIED
921 10:57:46.336 09/30/06 Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=51920D8301E57492 R_Cookie=0DC8CA40233A804A) reason = PEER_DELETE-IKE_DELETE_UNSPECIFIED
922 10:57:46.336 09/30/06 Sev=Info/4 CM/0x63100013
Phase 1 SA deleted cause by PEER_DELETE-IKE_DELETE_UNSPECIFIED. 0 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
Re: Remote VPN connection drop intermittently.
Is the time synchronized on the clients and the PIX?
Both are synch to different NTP source.
Based on the client logs, it looks like the client received an IKE Delete message from the Pix. Now, the question is.. why did the Pix send a Delete Notification.
Please post the complete logs from the VPN Client and Pix when you experience this issue.
Arul
Vpnclient and Pix Syslog. Also include "debug.txt" which have both debug cryp isakmp and debug cry ipsec.
XXX.XXX.XXX.148 being the client and gateway IP.
1026
