Community Member
Remote vpn problem with Pix501
We have successfully created vpn connection, but data doesn't move and we cannot ping any computers on the network?
What is wrong with my configuration?
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.1.0 NAT
access-list 101 permit ip 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0
pager lines 60
logging on
logging console debugging
mtu outside 1500
mtu inside 1500
ip address outside 83.x.x.212 255.255.255.0
ip address inside 10.10.10.150 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool 10.10.12.1-10.10.12.240
pdm location 83.145.x.x.255.255.255 outside
pdm location 10.10.10.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 83.145.227.254 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http NAT 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup vpn3000 address-pool ippool
vpngroup vpn3000 dns-server 10.10.10.2
vpngroup vpn3000 wins-server 10.10.10.2
vpngroup vpn3000 default-domain cisco.com
vpngroup vpn3000 split-tunnel 101
vpngroup vpn3000 idle-time 1800
vpngroup vpn3000 password ********
telnet timeout 5
ssh 83.145.x.x.255.255.0 outside
ssh 83.145.x.x.255.255.0 inside
ssh timeout 5
console timeout 0
terminal width 120
Cryptochecksum:4xxx
Community Member
Re: Remote vpn problem with Pix501
The access-list 101 is permitting 10.1.2.0/24
and pool for the client is 10.10.12.0/24 you should allow the 10.10.12.0/24
Community Member
I changed that, but didn't help. After I powered off pix and powered on again I did get the Vpn connection to work. However somehow I cannot use Pdm or SSH to connect to Pix, but that really isn't a problem. Thanks!
84
