RemoteAccess IP's not propagating in OSPF
I have a VPN-only setup with ASA5520s running Active/Standby failover. On the inside interface I have an OSPF setup with the ASA (both area 0). The ASA learns routes from the router. However, the router doesn't learn any routes from the ASA for RA clients. I've configured a pool of IPs which appear in the ASA routing table to come from the external interface and are /32s but those routes don't seem to propagate via OSPF to the inside router. I did try to redistribute the static into ospf on the ASA but to no avail.
Is there anything special I need to do to get these routes to propagate via OSPF?
Casey
Silver
Re: RemoteAccess IP's not propagating in OSPF
Post the running config of your device.
I can think of vpn pool network advertizement in asa ospf process, asa ospf does not know about vpn pool network unless you tell it to advertize it. Advertize the vpn network in your ospf process asa inside interface, can you try that please.
e.i, assume vpn pool network is 10.20.20.0/24
router ospf
log-adj-changes
area
network 10.20.20.0 255.255.255.0 area
Gold
is RRI enabled on your dynamic crypto map?
crypto dynamic-map DYNAMIC 10 set reverse-route
and make sure to redistribute static routes into ospf.
434
