Remove previous VPN setting from ASDM 5.0 for PIX not from command line
My original VPN setting did not properly function accidentally. I paln to remove the original VPN setting from ASDM 5.0 for PIX not from command line and re-setup again by using VPN Wizard.
1 REPLY
Silver
Re: Remove previous VPN setting from ASDM 5.0 for PIX not from c
You can use VPN wizard for configuring the ASDM.Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/netsec/secmgmt/asdm/v_5_0/asdmhelp.pdf
100
