Removing Telnet and FTP (keep SSH/SCP)
I dont want the sensors to run Telnet and FTP services, becuase I want to force anyone connecting to them to use SSH/SCP.
I edited the /etc/initd.conf and commented out the lines that start these services. However, this cannot be the "best method" becuase after I tried that suddenly the sensor stopped listening on port 22 and I couldnt connect to it with SSH (of course). When I uncomment the ftp and telnet lines in the inetd.conf, SSH/SCP/port 22 is open again. Weird. What should I do to remove these services?
BTW: on an unrelated note, the interface /dev/iprb0 (command and control) is the card which is assigned an IP address, and is used for connecting to the sensor. The /dev/spwr0 is the interface that only listens for traffic in promiscious mode and doesnt have an IP assigned to it, right?
Erik
1 ACCEPTED SOLUTION
Re: Removing Telnet and FTP (keep SSH/SCP)
Run sysconfig-sensor, there shoudl be an option in the secure communications area for disabling telnet and ftp. Sysconfig-sensor will then take care of making the proper edits for you.
For the 4220, and 4230 sensor appliances, your statements are correct for the interfaces.
NOTE: the 4210, 4235, and 4250 sensors have different interface names.
Marco
1 REPLY
Marco
127
