Reset ASA 5510 back to MFG Settings - Please help??
A network engineer was in the middle of setting up a customer ASA 5510 Firewall and left. We don't know the IP/UN/PW.
Is there a way to hard reset the firewall back to manufacture settings?
Thanks in advance.
Re: Reset ASA 5510 back to MFG Settings - Please help??
The easiest thing would be to do a password recovery, as described here:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1058131
Then you can simply reset the password and carry on where he left off.
Andrew.
Thank you, will try it - was hoping for the easy way out because not sure if he screwed up the config or still intact.
I guess there's no easy reset solution like the switch?
Really appreciate your time.
852
