Reset configuration
jparis
I have a pix 515 running 6.3(3) and i need to reset the configuration to factory defaults. i understand that the command to do this automatically thru PDM isn't supported on the 515, so what can i do?
mike-greene
Level 4
Level 4
Console to the PIX and do a write erase.
PIX(config)# write erase
PIX(config)# reload
Hope that helps.
write erase will ERASE the config... to reset to factory defaults, do the following:
pix>en
pix#config t
pix(configure)configure factory-default
that command isn't supported on the pix 515, thus my problem.
