Community Member
restoring a running-config
Hell-o,
I have copied our PIX515 running-config file to our tftp server on my pc for safe keeping. I wanted to add remark statements to the configuration file with notepad or wordpad and then copy it back to the PIX515. I cannot find anywhere how I would copy this modified config file back to PIX.. hope you can help.
TIA
Re: restoring a running-config
To tftp the config to your PIX: "configure net 10.1.1.1:/tftp/config/pixconfig".
Use the config command (http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/c.htm#xtocid7).
Hope it helps.
Steve
Anonymous
N/A
Hi Steve,
Followed the command line you gave and saw that this is the commmand in the documentation. Problem is, is just does not work. Perhaps there is something I need to do before I enter this command? Here is what I am entering it at the config# prompt.
configure net
:/tftp/config/
Hope you can advise as I am at a loss.
TIA,
Gary
Can you specify what happens when it doesn't work? Also, you can try it in combination with the tftp-server command, as per the doc posted before.
Steve
Anonymous
N/A
Steve,
It worked with config net :/PIX_newconfig. However it only worked for changing commands but not for adding comments. Perhaps it is the way I am added comments? I am adding comments to the config file as follows;
! ---This is a translation for our web server
176
