Restricting iexplorer with CSA ?
Hi all,
Does anyone have any ideas on how to use CSA to restrict iexplorer to only work when the host has an address of a given subnet?
ie. iexplorer.exe may only be allowed if the host has an addresse in the subnet of 192.168.2.x/24 ?
KDAM
Blue
Re: Restricting iexplorer with CSA ?
You could use a system state set to allow or deny iexplore.exe when the host address matches a given address range.
Hi, You could create two rules. First a Network Access Control rule DENY when Application in the following class = iexplore.exe attempting to act as a client TCP/0-65535, UDP/0-65535 communicating with host address 0.0.0.0-255.255.255.255. using local address 0.0.0.0-255.255.255.255. Then create an Allow rule to ALLOW when Application in the following class = iexplore.exe attempting to act as a client TCP/0-65535, UDP/0-65535 communicating with host address 0.0.0.0-255.255.255.255. using local address 192.168.2.0/24.
I would test this and turn on logging. You may need to adjust it some. Hope this helps.
112
